I recently received an email from the Autodesk Construction Team announcing a major rebranding. Most of you probably received the same email or saw the Forma rebranding on LinkedIn or other platforms. On March 24, 2026, the Autodesk Construction Cloud (ACC) as we know it will be rebranded as Forma. If you’ve been following the industry trends, you know this isn’t just about new name or a new logo. It’s a fundamental shift in how Autodesk wants the platform to handle data across the entire project lifecycle.
Here is the breakdown of the new names:
| Current Name | New Name (Effective March 24) |
| Autodesk Docs | Forma Data Management |
| Autodesk BIM Collaborate Pro | Forma Design Collaboration |
| Autodesk Build | Forma Build |
| Autodesk Takeoff | Forma Takeoff |
| Autodesk Estimate | Forma Estimate |
It’s More Than Just a Name
At first glance, many comments saying this as “just another marketing rebrand.” But if you look back at the vision Autodesk shared years ago (and some great analysis by Martin Day in AEC Magazine), the goal has always been to create “one platform to rule them all.”
By bringing Construction Cloud under the Forma umbrella, Autodesk is signaling that the wall between their different solutions are coming down. They want a unified industry cloud where data flows from and to different solutions seamlessly. While this can be challenging, it is a good plan.
Autodesk has different platforms. Some software runs on top of AutoCAD, but Autodesk also has Revit, Navisworks, etc. Converting data between them can be tedious and time consuming. If Autodesk can’t make all of their solutions running on one platform, why not having a data platform to manage all the data? Like now we already can link topography from Civil 3D in Revit and open a saved view in BIM Collaborate from Navisworks. I expect we can see more software can consume data from Forma in the near future.
Is the Naming Getting Confusing?
While I understand the logic, grouping everything under one “Industry Cloud” brand, I can’t help but feel the naming is getting a bit confusing.
For years, we’ve spent time explaining to clients and teams BIM360 rebranding to Autodesk Construction Cloud. Now, we have to re-train everyone to use “Forma” as a prefix for everything. Autodesk Forma used to be the conceptual site designer, but now the whole Autodesk Construction Cloud is Autodesk Forma. When someone says, “Is it in Forma?” are they talking about the early-stage design tool, or the common data environment? And will the desktop software will have new names too?
We’ll likely be spending a lot of time clarifying which “Forma” we’re talking about in meetings.
The Concept is Not New
This concept isn’t actually new. If you look at the manufacturing industry, companies like Dassault Systèmes have been doing this for a long time with the 3DEXPERIENCE platform.
They successfully unified design, simulation, and manufacturing under one massive ecosystem. It looks like Autodesk is aiming for that same level of “single source of truth” for the AEC industry. It worked for manufacturing because it eliminated data silos; the question is whether the fragmented nature of AEC will allow for the same success.
The Transition: What’s Next?
Autodesk has confirmed that the core functionality and UI layout will remain the same for now. Your current projects and data aren’t moving; they’re just getting a new badge.
However, how will Forma support customers who still rely on traditional, file-based methods? Not everyone is ready for a pure cloud-data environment, and the platform needs to remain accessible to those who aren’t living in a 100% “connected” world yet. Interesting to see how it goes.
What do you think about the shift to Forma? Does it make the ecosystem clearer for your team, or is it adding another layer of complexity? Let us know in the comments.
