Constructing an Elbow with Loft
Join the forum for Designers!
Your expertise is vital to the community. Join us and contribute your knowledge!
Join the Forum Now
Share, learn and grow with the best professionals in the industry.
Lofting a Threaded Elbow: A Common CAD Workflow Challenge
When modeling a male-female threaded cast iron elbow, the choice of the correct CAD strategy can quickly become a point of debate among professionals. A recent discussion on the Italian engineering forum cad3d.it highlights a specific hurdle: the transition between two distinct cross-sections along a curved path. The user, attempting to create the fitting using a Loft feature, reported difficulties that many mechanical designers will recognize.
The Core of the Problem: Loft vs. Revolution
The initial approach involved two separate Revolve features, but the user encountered a blockage precisely at the curve of the elbow. This is a classic limitation of the Revolve tool when dealing with non-concentric or varying profiles along a bend. The logical alternative was the Loft feature, which allows the software to morph between two different sketches (the male and female threaded ends) along a defined trajectory.
However, the Loft operation proved equally challenging. The user experimented with two distinct guiding strategies to control the transition:
  • A single central guide curve to define the spine of the elbow.
  • Two separate guide curves to better control the outer and inner walls of the fitting.
Despite these attempts, the geometry failed to generate a clean, manufacturable solid, particularly at the bend. The attached image from the forum shows the typical result: a twisted or pinched surface where the Loft tries to interpolate between the circular profiles of the threads and the curved path.
Why the Loft Fails on a Threaded Elbow
From the analysis of the community feedback, the issue likely stems from the alignment of the sketch vertices. When lofting between two circular profiles, the software must match points along the perimeters. If the start points of the two circles are not aligned with the guide curves, the resulting surface can twist. This is especially critical for a threaded component, where the internal and external diameters must remain concentric and the thread profile must be preserved.
The use of two guide curves is generally the more robust method, as it forces the Loft to respect both the inner and outer boundaries of the elbow. Yet, the user’s experience suggests that even this method requires meticulous sketch geometry. The guide curves themselves must be tangent to the end profiles and must not introduce self-intersections.
Alternative Strategies from the Field
While the forum thread does not conclude with a single definitive solution, the discussion points toward several alternative workflows that experienced users often recommend for such parts:
  • Sweep with a tapered profile: Using a Sweep feature with a single profile and a path, combined with a draft or a variable section, can sometimes handle the transition more predictably than a Loft.
  • Surface modeling: Building the elbow as a series of surface patches (using Boundary Surface or Filled Surface) and then thickening the result. This offers maximum control over the curvature but requires a higher skill level.
  • Multi-body approach: Modeling the straight threaded sections as separate bodies and then using a Loft or Sweep to create the curved connecting section, followed by a Boolean operation to combine them.
The core takeaway from the cad3d.it discussion is that while the Loft tool is powerful, it is not always the most direct path for a threaded elbow. The geometry of a pipe fitting demands precise control over the cross-section along the entire bend, a requirement that often pushes designers to reconsider their feature tree.
To explore all the technical details, read the full responses, and actively participate in the debate, we invite you to visit the original discussion on the cad3d.it forum (in Italian).
Join the Forum Now
